active suspension q45
snowman447
Car: 1990 nissan infiniti q45
hey there, i have a 90 q45 with the active suspension and just recently the light on the dash for it has come up red, which is usually green if i set it 2 high. does this mean there is a problem?
thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yes.
Check your active suspension codes, read some posts and you'll be all set.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Welcome to NICO, snowman.
Read all posts by TexasOil in particular, then all by Q45tech.
How are your timing chain guides?
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Check your Active Fluid level. When it drops, green light goes to red light.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
My fluid level is ok, but the self diagnostics throw either a F/L height sensor (code 22) or F/R height sensor code (code 21)....
Any fault in the ACTSUS system will cause the green "height" light to go out, and the red "ACTSUS" light to activate.
The links to clearer pics....(you can zoom in on them)http://img.photobucket.com/alb...1.jpgh ... lb...2.jpg
