Ozzie »
https://forums.nicoclub.com/ozzie-u33476.html
Thu Jan 12, 2006 1:33 pm
OK.When I start the car (sus switch on "H"), the car raises, and the "height" light comes on... (as its meant to).
But within 15 seconds, the front starts to sink back down, (consult shows faults with the front height sensors)... and then the ACTSUS light comes on...
are the front height sensors shot... or are my accumulators dying?Or is it another problem altogether...
PS. Sometimes the suspension will sit higher with a bit of driving (might behave itself for 10 to 15 mins) but still ends up setting off the ACTSUS light.
I think the consult is telling me the front height sensor fault because they are being triggered by the car dropping, not because they dont work anymore.
I have plenty of fluid in the reservoir, and havent had a fault from the rear height sensors... only the front. My mechanic did a full diagnostic on the Active suspension system, and used the consult to bleed and prime the system..... but i still had the ACTSUS light come on on the way home.
Any ideas????
