Yes, I've just finished my active conversion. You could simply just remove the active suspension struts AND springs and just replace them with the standard struts but Texasoil is looking for entire active suspension systems to recharge. Besides, the entire system is A LOT of extra, useless weight for a Q to be chuggin around.
Another note, you have to disconnect the outlet from you powersteering pump to active suspension pump and loop it back to the p/s or else your p/s pump will have a very, very short life thereafter. The multivalves located in the fenders, for of the front wheels are very, very difficult to remove. I had to use a dremel to cut the hoses. Take a look at it, you'll see what I mean. If you have anymore questions, my email's
[email protected]. Good luck on the conversion.
