Active Suspension Fluid Type A
Aussie Q45
Car: 1990 Nissan Infinity Q45. '46 Ford Super Deluxe (Restored)
The Hydraulic pump for the PS and Suspension has been overhauled and I can't buy "Nissan Active Suspension Fluid Type A" any where in Australia.
Does any one know of a substitute fluid that will be safe to use. Is the recommended fluid a mineral or synthetic and what is its viscosity? I feel sure that I will be able to find something in Australia, but if not I will have to import it from the US or Japan. Citroen use a product called "LHM" and RR use Dextron 2 or 3, at the moment I have a gut feeling that the LHM is the way to go, but if I'm wrong!!!!!
Any feed back/information at all will help me with my decision.Thanks in advance
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Search for texasoil's posts... he doesnt have that many so read them all!
If I recall theres some MB stuff you can use... I dont remember off hand...
Aussie Q45
ThanksHave emailed TEXASOIL and am waiting for a reply.
Aussie Q45
What does MB stand for ?
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Mercedes Benz
Aussie Q45
Doh!! Sorry, still comming to terms with your acronyms
rosemaryadelaideaustralia
Car: 1994 q45 nissen infiniti
HEY THERE, NOT SURE HOW THIS WORKSJUST NOTICED YOU ARE ONLINE I NEED ANSWERS TO SOME SUSPENSIONS QUESTIONSCAN YOU HELP IM NOT COMPUTER LITERATE SO I DONT KNOW HOW TO CONTACT YOU
Aussie Q45
Email is cheapest, [email protected], but you are more than welcome to phone Brisbane (07) 3273 8299there are just a few Imported Infiniti's in OZ and the best info you can get is fron NICO and Q45.org.
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
Did you get the answer you needed regarding substitute suspension oils? Pentosin sells one, as does Mercedes. Failing that try and find a good brand antiwear hydraulic oil with rush and oxidation (R&O) protection. 5 centistokes (5cs) should work OK. It's got to be antiwear and R&O. Viscosity Index higher than 150 is desirable.
texasoil
'94 Infiniti Q45A
LHM fluid is on the light (too thin) side, but OK otherwise. I had a Citroen SM for 24 years and know the stuff well.
Aussie Q45a
Car: '89 JDM Q45a, Skyline GTR, '95 Fairlane. MB Winnebago
texasoil wrote:Did you get the answer you needed regarding substitute suspension oils? Pentosin sells one, as does Mercedes. Failing that try and find a good brand antiwear hydraulic oil with rush and oxidation (R&O) protection. 5 centistokes (5cs) should work OK. It's got to be antiwear and R&O. Viscosity Index higher than 150 is desirable.
BrianFinaly found this old post from Texasoil, Thanks
The oil I'm using is a Mobil ProductAERO HFMil-PRF-5606NATO H-515Aviation Hydraulic FluidThe only concern I have is that it's RED and you guys keep talking about the GREEN Active oil. Hopfuly it's only the dye that's the diffrence !!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Good going, but I have no idea about the significance of colors.
Email Keith as he is a gentleman and very knowledgeable about lubricants and oils.
If you want the proper fluid, Joe can send it to you I think.
http://www.infinitpartsusa.com
96Qowner
Car: 1996 Q45
I bet he'd even talk on the phone. His number is on his website:
http://www.activesuspensionsystems.com/info.html
