Active Suspension Fluid?
KO
Is the an alternative to expensive OEM fluid?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Not a good permanent solution.
you need to read all posts by TexasOil.
http://www.q45asuspension.com
You can get fluid from
http://www.infinitpartsusa.com
KO
I always like to use what is correct but thought there might be an aftermarket exact equivialnt
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Read the posts! Mandatory for active owners who wish to maintain their cars!
djazzmo
Car: 2002 Infiniti Q45
maxnix wrote:Read the posts! Mandatory for active owners who wish to maintain their cars!
What post are you reffering to?
Raxephon
Car: '04 RX8...for the moment...
maxnix wrote:you need to read all posts by TexasOil.
Those.
qship96
Car: 1996 Infiniti Q45
I DUNNO
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
nothing usable is lower in cost. There ARE some alternatives if OEM is unattainable. I will not make broadcast recommendations except to use OEM, carray a spare can or two in the trunk
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
reason theres no aftermarket alternatives because nissan was really the only one to make this kind of suspension until maybe 5 years ago or so.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
The active fluid is classed as "hazardous", and therefore can't be imported to Australia. (I have no choice but to use an alternative)
There is one available here, but I guess it doesn't matter to you, as you are in the US.
Raxephon
ozzie! wrote:The active fluid is classed as "hazardous", and therefore can't be imported to Australia. (I have no choice but to use an alternative)
So what is it?
KO
I tried using an alternative mineral based fluid bu the viscosity was too high and the ride height topped out
KO
There is a small leak in the rear of the car that has already cost me about $200 worth of OEM fluid.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
KO wrote:There is a small leak in the rear of the car that has already cost me about $200 worth of OEM fluid.
Look on Keith's site and get it fixed.
Ozzie
'06 MK5 Golf tdi
anlasak wrote:
So what is it?
Mobil
AERO HF
Mil-HF-5606
Aviation Hydraulic Fluid
1 US Quart
It's my understanding that it is used for the landing gear hydraulics of aeroplanes.
KO
I tried replacing the o rings but it didnt hold.
KO
I know it cant be some unobtainable material
