fxjackso »
https://forums.nicoclub.com/fxjackso-u250.html
Sun Apr 18, 2004 7:13 pm
If he didn't fill after replacing the strut accumulators, and the required bleeding, you must be very low. You can reuse hydraulic fluid that you pump out during bleeding, but only if it's bright green and doesn't have any smell.
After you refill, switch to diagnosis mode and pump the brakes to erase the cdes, then start over. 41 is the pump code, and remember that the accumulator switch will also trigger it.
