Active suspension car knocking on left side
BHurvitz
91 Q45a 110,000 miles recharged strut and front and rear accumulators. The right side rides like new, but the left side has a slight knock in the front and back when I go over bumps in the road. One fellow though it might be the rear valve body. Any ideas. My power steering pump is also blown out and I am thinking of removing the active system and replacing it with a standard suspension if there is no fix for the active knocking problem, seeing that the active pump is attached to the power steering pump. That unit is in the $400 range. Would appreciate any thoughts and feed back.RegardsBob
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
the knocking sound can be the piping rattling against something. It can be exacberated or caused by flat main accumulators and flat valve accumulators.
Drop me a line off forum and let's fit it.
