texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Mon Dec 11, 2006 7:10 pm
changin ghte fluid is real easy. Simply disconnect the big hose coming from the active reservoir and drain the reservoir. Refill the reservoir and drive on.Run the active self diagnostics if the actsus warning light is on. Low rear end --somebody may have adjusted rear height sensors for 'low rider' look
