active stabilizer bar bracket
Jehangir
Car: 1992 Infiniti Q45A
I was changing the bushings on my stabilizer bar and my tourque wrench is not working correctly. I must have overtightened the bolt and broke it. Now, I guess I need a new stabilizer bar bracket.
1) Can I drive the car with only 3 bolts connected.
2) Does the active G50 have the same size bracket as the nonactive
3) anyone have this part for sale.
Jehangir
Ohh I forgot. I was working on the front stabilizer bar.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I did the same thing... I dont know why youd need a new bracket, the bracket should just be dangling....
In my case, the eprosn who worked on my bar before me was nice enough to have tightened them up too tight so I went ot undo it and it broke!
either way, have someone remove the bolt ASAP but you can drive it like that, Ive driven mine for a while. Its not ideal, but the front sway bar is beefy enough that you probably wont bend it....
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Active and t model front stabilizer bar is 1 mm less in diameter than standard.
