ChampionSound »
https://forums.nicoclub.com/championsound-u122217.html
Mon Mar 15, 2010 10:25 am
so i know this is borderline between the audio and 240 forum so mods feel free to move it as you wish
i have a 93 240 with the active speaker package. it came with an alpine 9813 headunit already in the car so the wiring is pretty messy. i found out my door was leaking when my speaker started going haywire on me so i pulled everything apart and found out that whoever installed the headunit and stuff did not bypass the stock amps in the door.
so i have a few questions. what were the power ratings on the amps in the door? i am trying to decide if i want to just bypass the amp and run my speakers off my HU or just leave that s*** in and keep the amp
second question is, if i bypass the amp, i am having troubles with making out the wiring diagrams in the fsm
i have for the connecter leading from the HU the following colours
light greenblacksolid blueblue w/ white stripeblue w/ yellow
the colours leading out of the connecter to the amp are (same order/ pairing with the harness)
dark greenblackblueredbrown
(light green goes to dark green, blue w/ yellow goes to brown etc)
what wires would i need to clip/ tape off and what wires would just be my positive and negative for my speaker? i tried searching but all i could get was the rear amp bypass which i have done already and the colours arent the same as the front
thanks guys i appreciate it
