bruce.weiland »
https://forums.nicoclub.com/bruce-weiland-u51217.html
Sun Feb 25, 2007 5:53 pm
Active Q45’s wheel size affect on system function.
As you know the active cars (‘91 – ‘95), and all cars of that ventage, came with 215x65x15 95V 35 psi tires mounted on 15x6.5 wheels.
I have the BBS OEM West German made wheels on my ’94 Q45a.
Many on this board have recommended that Q owners go to larger than OEM diameter wheels. And rightly so. Perfromance tires are getting very hard to come by in 15” diameter.
On my two previous active Q’s I ran Yokohama AVS Intermediates (many sets, extremely happy with them until they were discontinued) 255x50x16 on 16x8.
There are very few performance tires available in 16” that are the right size and load rating for our cars.
That leaves 17” or 18”. I had 17’s and did not like the combination.
Keith Bowers (active specialist ) has stated that, in his opinion, 18’s do not belong on an active car. He mentioned that the system is “tuned” for the frequency of the OEM wheel tire combination. Keith also has a Mercedes with ABC (automatic body control – a system that in many ways is very similar to the Infiniti active – but about 10 more years of computer development and the hydraulics modulate the spring perches rather than a shock/acctuator). His experience with his Mecedes with a wheel and tire combination that is 10 lbs lighter than OEM, but with ½” less sidewall, is that it comprimissed the system to some extent.
I need some new tires on the Q. It has lots of tread left on some very, very old Michelin Symmetry 215x65x15 95S 500 AA.
I decided to try some 18’s on my active just to see what they would do. I have recently replaced all 9 accumulators and the system is working flawlessly. I have an I30 with new 215x55x16 Goodyear F1 GS-D3. I have not tried this on the Q yet. I have a G35 sedan with OEM sport wheels and tires with about 9k miles on them. 235x45x18 94W 180 A A, Bridgestone Turanza E33 . I realize that these are 26.5” unloaded diameter as opposed to the 26” OEM. Additionally they are 51psi tires, so I had to really pump them up before I did my test.
The OEM 15” BBS tire/wheel combination weigh approximately 35 lbs ea. The wheels/tires from the G35 weigh approximately 45 lbs. each.
Here is my experience.
First, Keith IS RIGHT! 18” wheels screw with the dynamics of the active suspension. The first thing I noticed in the first 100 feet of driving was a lot more road noise making it into the cabin. Secondly, acceleration seemed, seat of the pants, to be noticably affected in a negative way. It could be the slightly larger diameter, or more likely the additional 10 lbs of rotating mass on each corner, or both. It certainly did not accelerate as quickly.
At speed (60 to 80) the system seems to over compensate for sweeping dips and rises. I belive the two 16 bit processors and active software are being confused by the short sidewall (1.5” less than OEM), in that the data from the wheel position sensor, and the vertical accelerometers are initially changing more quickly than would be the case if the 5.5” sidewall was taking up the initial portion of the road uneveness.
The only benefit to the 18’s was less body lean on turns. That can be made up for to some extent by poly bushings on the bars, so that is coming.
OK, so other than price and the 26.5” unloaded diameter, tell me why I don’t want Pirelli P4000E’s.
Specs: 225/65 ZR15 99W (1709 lbs.) SL, 180 A A, 44 psi, 25 lbs, 6-8” rims, 9” section measured on a 6.5 rim.
OK, flame away. I can take it.
BruceOnce a Marine, always a Marine
Modified by bruce.weiland at 10:10 PM 2/25/2007
