Active Q: Tire Pressure?
PachoC
Hello,
I did some Search on the tire pressure topic (i.e. zerothread?id=144694) and found several posts recommending a pressures in the 33 to 38 psi. Does this apply to the Active too? The placard on the Q says 29 psi and this is what the guys at Costco put on my new Exaltos (225/60R15).
Or should I ignore this and go with the 80% of the Max Sidewall pressure?
Tks!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Calculate what the load capacity is at the lower tire pressure vs. the higher one. Don't forget to consider dymaic overloadings during crnering, braking and heavy loading.
szhosain had a great chart one time in an xls spreadsheet.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I've got the same question and don't think I'm really smart enough to read all those charts. What does everyone run in their tires. I've got the same Exaltos from Costco running N2 at 29.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Gas composition doesn't matter for load carrrying capacity.
I got kicked out of Costco for explaining why the G50 required at 35 psi minimum because of dynamic loading.
There is a previous thread all about this. Atmosphere and tire design still pretty much the same in the intervening 2 or 3 years.
szh
Car: 2018 Tesla Model 3.
maxnix wrote:Calculate what the load capacity is at the lower tire pressure vs. the higher one. Don't forget to consider dymaic overloadings during crnering, braking and heavy loading.
I still have it!
If anyone wants a copy, send me e-mail ...
Z
szh
AlabamaDan wrote:What does everyone run in their tires. I've got the same Exaltos from Costco running N2 at 29.
29 psi is too low. Tire load index is measured at 36psi. If you have 95 or 96 load index tires, then you should be running at 36 psi. If you have 99 or 100 load index tires, you can drop down to 33 psi, but don't go below that. If your tire load index is less than 95, then you should plan to change tires soon and run at 40 psi till you do so!
If you run 33 psi, then please plan to check often (at least once a week or once every other week) with an accurate tire pressure gauge, cold measurement (in the garage, no sun and no driving at all) and then correct the pressure ... all tires drop about 1 to 2 psi every other week.
Z
PachoC
The 225/60R Exaltos are rated at 96V.
96Qowner
Car: 1996 Q45
36 psi, then.
PachoC
Perfect.Tks.
cccpman
Car: 1990 Q45
kicked out of costco. maxnix your cracking me up. Q owners just are not safe anywhere these days
