ACTIVE G50 Q45 ACTUATORS
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Has anyone with an Active Q ever replaced the front and rear actuators? Is there a way to test them? At $750 a piece, they're not cheap. I'm wondering what kind of condition mine are in considering I have 147,000 miles on my car and the rubber boots are ripped on all 4 of them.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
From what I've read by texas oil if theyre not leaking theyre probably fine... Get those boots replaced!
lino
Bump
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
lino wrote:Bump
http://www.q45asuspension.com
Read all of texasoil's posts.
franknitty69
Car: 1995 Infiniti Q45a
i've replaced the front. my ride was very harsh before i changed it. there's no way to test the accuators. i would recommend to make sure all other components are working. if your ride is bumpier than usually or then it's probably time to change those accuators.
when i changed the fronts, the car drove like butter. can't wait to do the rears.
get with keith bowers!
lino
franknitty69 wrote:i've replaced the front. my ride was very harsh before i changed it. there's no way to test the accuators. i would recommend to make sure all other components are working. if your ride is bumpier than usually or then it's probably time to change those accuators.
Thanks for the reply. I already did all 9 accumulators with Keith and also replaced the Front Vertical G Sensor which happened to fail shortly after I replaced the accumulators.
Where did you buy the accuators and how much $$$ ?
Thanks
franknitty69
sorry for the late reply. i get all my active stuff from keith bowers (texasoil).
i paid $350/pair for the front. there is a core charge of $200, but you get that back once you send in your existing ones.
