As I recall, the main pump for the active system is down there close to the radiator. Could the leak be coming from it? You might be able to get a look at it through the vented wheel well liner. If not you'll have to remove the tire and the liner.Jmanolinsky wrote:While searching for my AC problem, I noticed my 94a is leaking active fluid right at the bottom corner of the radiator (on the AC side). Is this likely a loose fitting or what.
