silver2k2 »
https://forums.nicoclub.com/silver2k2-u57091.html
Wed Jan 28, 2009 6:40 pm
I was considering a project that involves using the active cooler and the active fan.
The project would use a thermo valve to open the trans fluid valve at 170 degrees and activate the fan to quickly cool the fluid.
the active cooler sits down in the wheel well and thus does not dump any heat into the cooling system.
looking for ideas and part links to build this system. I would even consider making kits for others if interested
