ACT Extreme street stage 3 clutch question....
LeroyBrown
Car: 1995 nissan 240sx s14 blacktop
So tonight i raced a SS camaro. We raced from a dig than three runs from roll. After the races my clutch felt a lil harder to compress than usual. I checked all the fluids, A ok everything perfect. It feels like it did when i first put it in. I drive my car short shifting all the time just cruising it as a DD. My friend said it might be that it got warmed up and it is working the way it is supposed to.Any idea what it may be? It goes into all gears perfect.
sunnys14
Car: S14
How new is the clutch?
ACT xtreme is probably the heaviest clutch feeling I've ever felt.
Jables
Car: 1995 RB26DET S14, 1991 RB25DET S13, 1992 S13 LS1 Coupe
Only two things that will normally make a pedal feel difference
Hydraulics!
OR Something lodged or has broken in the clutch itself.
Seeing as you said it still shifts and everything works i would probably lean more towards hydraulics.
Did you install a new master and slave at the same time when installing the clutch?
LeroyBrown
It feels good now. i think that night it just got harder because i was really ripping it and dumping on it.
sunnys14
Car: S14
Thats weird...
When you beat the crap out of a clutch or your brakes, the fluid can boil and you will get a mushy feeling from the line expanding. I've never had a pedal get stiffer from beating on it.
