act clutch porblem
Okay
I know about the whole removing the alignment pin to make it fit, but I even romaved all of them. Seems like the holes in the pressure plate, where the bolts go into, are a little off so only 3 bolts fit. Anybody else has issue with the ACT HD kit? I compared it to the stock pressure plate and the holes are a little off. ahhhgg
float_6969
Yea, I've heard that some people have had to open up the bolt holes on the pressure plate a little bit to get it to work.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Yep, I had to reem out the bolt holes a little on my CFDF to get it to fit.
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
is anyone besides me alittle bit worried about doing that? like its not 100% balanced afterwards? idk i had to buy a CA clutch to be at ease
Okay
uhh...how do you open up the bolt holes?with a drill?
NeedCAforS13
Car: CA swapped S13 coupe
yeah, you have to open the holes SLIGHTLY sometimes with a drill. Its so little I can't see it making a difference.
Taser
Car: Nissan Silvia S14
Okay wrote:I know about the whole removing the alignment pin to make it fit, but I even romaved all of them. Seems like the holes in the pressure plate, where the bolts go into, are a little off so only 3 bolts fit. Anybody else has issue with the ACT HD kit? I compared it to the stock pressure plate and the holes are a little off. ahhhgg
Sorry, I know this is a pretty old one.
I just tried to install the ACT NS4-HDSS Kit and at least one alignment pin doesn't line up with the pressure plate (N-025). The bolts are not the problem but the pins and I tried it in every way.When I read your post, I think this problem is already known. I tried the "search" with no success. Does anybody have a solution?
Thanks
boost_boy
Drill the pressure plate to match the dowel pins. I'm totally against removing one to make it fit.
Dee
float_6969
I'm with Dee as well. Drill the plate for the dowel pin.
Taser
boost_boy wrote:Drill the pressure plate to match the dowel pins. I'm totally against removing one to make it fit.
Dee
Thanks for your reply. I'm a little bit surprised that I have to modify the pressure plate. Isn't is normaly that whan a clutch manifactury sells a clutch for a car (180sx, CA18DET e.g.), the clutch should fit without modifications?I sent Act a mail as well......answer: Never heard of that problem. Essentially the cover used to manufacture this pressure plate is a factory Nissan cover and there are no changes to the alignment pin holes!This sucks
boost_boy
They Bs'd you by giving you one for the KA instead of the CA. Not the big of a deal, but I know what you mean.
Dee
