ACT 4 & 6 puck question
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
Does the 4 puck and 6 puck engage the same at take off..??
Which will last longer..??
j-z
Car: 95 240sx
sorry cant answer youre question, but would you mind checking out the z32 maf wiring thread. thanks
rn240sx
09 Ninja 650R
06 Suzuki S40
j-z wrote:sorry cant answer youre question, but would you mind checking out the z32 maf wiring thread. thanks
Was that thread posted by you..??
9sec240
Car: S14.5 Turbo KA
4 puck will be stickier and will engage more quickly... 4 puck will be harder to drive but will hold more power... 6 puck will last longer... I believe the 6 puck is way too heavy of a disk and causes shifting issues... On the twins car it would lock out the next gear at above 6500 rpms...
rn240sx
09 Ninja 650R
06 Suzuki S40
9sec240 wrote:4 puck will be stickier and will engage more quickly... 4 puck will be harder to drive but will hold more power... 6 puck will last longer... I believe the 6 puck is way too heavy of a disk and causes shifting issues... On the twins car it would lock out the next gear at above 6500 rpms...
What would you recommend for 414 ft lbs ..??
j-z
Car: 95 240sx
the thread im refering to was made by chezedik. its on this page with 15 replies or so. anyways, ill be making the same power/torque numbers you are and i went with the spec 6 puck. i picked it up from enjuku for their sale price ($309) out the door. im hoping to have everything running this weekend. used all the parts from the ams build kit today. first time motor build for me, so it was quite fun. the clevites all checked out too. good shlt ivan.
9sec240
Car: S14.5 Turbo KA
rn240sx wrote:What would you recommend for 414 ft lbs ..??
The ACT HDSS worked for the twins car till about 500 lbs... Shifted like butter too....
rn240sx
09 Ninja 650R
06 Suzuki S40
No way, thats what i have now and it wont hold anything past 275 ft lbs..
9sec240
Car: S14.5 Turbo KA
rn240sx wrote:No way, thats what i have now and it wont hold anything past 275 ft lbs..
Is your flywheel stepped?
wild_maxx
Car: 90 TT pearl yellow z32
is the flywheel required to be stepped? I remember looking it up when i resurfaced my flywheel and it called for something like .002" step... what do u reccomend?
j-z
Car: 95 240sx
thats a new term for me. what do you mean by stepped?
rn240sx
09 Ninja 650R
06 Suzuki S40
Quote »Is your flywheel stepped?[/quote]Like j-z wrote... what is stepped..??
Anyways, when we did the motor rebuild, my buddy that was helping me noticed that the inserts on this fidanza were kinda worn out and the bolts were nearly comming thu but the inserts still had some life to them so we left it alone. But what we both failed to realize was that we rebuilt the motor with the sole intention of more boost and more whp. I went from ~270 whp b4 the build to 314 whp and then to 414 whp after the build. It may be the flywheel inserts that are gone or it could be the clutch or both.. Ive been too lazy to drop this transmission to find out..
drEameRvaJ
Car: 1997 Nissan 240SX SE
Which clutch would last longer?4 puck, 6 puck or street?And how do you "step" a flywheel?Let us know what that term is.And would someone help with the clutch choice, I'm in need of a new clutch.Thanks!
drEameRvaJ
Bump for a reply.
240sxproblems
Car: 95 kat
stepping is usually done buy the machine shop that surfaces your fly wheel. What it is a 2 stage surfacing processing that puts a small step into the surfaced portion of the fly wheel. It is suppose to be done that way on all ka fly wheels.
9sec240
Car: S14.5 Turbo KA
rn240sx wrote:Like j-z wrote... what is stepped..??
That could certainly be an issue...
There are two factory flywheels... One is completely flat and the other is stepped... The stepped flywheel has the area where the clutch disk rides stepped up from the area where the pressure plate mounts... This effectively puts more pressure on the disk and keeps it from slipping... I dont know which years have the stepped or flat flywheel... I believe the SOHC and the 95 up all have the same clutch / flywheel and the 91-94s have the other...
j-z
Car: 95 240sx
yeah my stock flywheel is def not stepped its completely flat. but thats cool that i learned something new. so you can take a flat flywheel and machine it stepped to where the pressure plate mounts it lower than the contact surface. and damn run something like a street disc and have it grab like a puck disc. if my 6 puck ever starts to slip (doubt it will) i can always take the flywheel to have it stepped.
9sec240
Car: S14.5 Turbo KA
drEameRvaJ wrote:Which clutch would last longer?4 puck, 6 puck or street?And how do you "step" a flywheel?Let us know what that term is.And would someone help with the clutch choice, I'm in need of a new clutch.Thanks!
The 6 puck will last longer....
rn240sx
09 Ninja 650R
06 Suzuki S40
Im not sure if fidanza flywheel's are stepped from the factory, but i just purchased it and threw it on the motor....
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
I used the ACT and 6 puck before but I didn´t like it. Bad crappy feeling in the pressure plate and very weak, only 400 Nm before if went up in smoke... I didn´t step the flywheel but this was a SR20 car and ACT never said a word about stepping.Tested Spec after this and the same problems, both probably use a painted stock plate...
After this I started using Sachs instead and now I don´t need sinter, their pressure plates are really strong, 600 Nm with OEM disc. As a bonus you get a huge left leg, hard to press...
/Mike
