boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Sat Mar 06, 2010 3:30 pm
Just an FYI for you guys/girls that are wanting to refreshen your engines and think that buying expensive components is the way to go, well not always. I don't think anyone needs an introduction to ACL and their products, but I've ordered two sets of ACL race rod and mains and have already destroyed a complete set of rods and mains in less than 10 minutes.
When I installed the bearings into the engine and installed the caps, I noticed that my normally functioning engine with a freshly polished crank was extremely hard to rotate, but I figured it was just because of the newly installed parts (not normal for me, but I accepted it). I then reassembled my motor adding a new oil pump, rings, NISMO H/G, ARP studs, a different head using upgraded heay duty valve springs, the swapping of my reground cams to my JUN cams and the addition of a GT35R (this car has seen many turbos in the last two months). Once installed into the car, the damn thing rotated slowly while starting, but it did crank. When I would try to let it idle, it would just shut down hard as if something was binding.
I would experiment with for a few more minutes until the starter started smoking. Even though premature, I took a compression test to see how the engine was sealing and the compression yielded an equal 150psi across the board, but I knew I had to pull the engine back out of the car, so I started tearing it apart. Once I got it back out and opened the bottom end, I discovered one of the inserts to my #1 rod bearing took a beat down and the other bearings were getting some work as well. So I removed the ACL inserts, repair the scarring of my #1 journal, repolished the crank, re-installed everything using bearings that are not on the normal radar and the engine rotated freely with just my hand turning the crank's nose.
Hypothesis: Those ACL bearings claimed to be standard, but they didn't fit like standard bearings. I measured the mains and they were on point with the original bearings that were removed from the motor which had almost no wear, but I didn't measure the rods, even though all of them wasn't screwed-up.
I was hard-headed and went against my own rules which resulted in me creating extra work for myself. Remember, if it doesn 't feel normal, something is definitely abnormal. Car runs sweet now with only 15 miles on the engine and it has already seen 18psi of boost. Happy boosting ..........
Dee
P.S. Here's some pics of the carnage: The main bearing on the right is the original bearing from my motor. As you guys can see it's condition is pristine, but the ACL mains aren't so bad either; and keep in mind these things may have been in the car for only a few minutes.
These were showing signs of something not being happy between the crank and the bearings. Main clearances were checked, crank was mic'd and the clearances showed signs of promise, but this I won't try to explain.
These are your rod bearings in order from left to right cyl #1-4. AS I stated before, cylinder one was under stress. And no I didn't over-tighten the bearing caps. Before one starts commenting on their current condition, keep in mind that they were already discarded after my discovery, so they have extra scratches on them. And that extra streak of light on all the bearings is the wonderful 80 degree sun that I was enjoying .
This all of the bearings together. I pulled these things out of my garbage to provide pics, so please don't give me any smack. And lastly Ryan, I do not have a polaroid nor have I ever owned one , but I do have a lot of cassette tapes in my garage if interested .
Modified by boost_boy at 8:15 PM 3/8/2010
Modified by boost_boy at 7:35 PM 3/18/2010
