viperdoc »
https://forums.nicoclub.com/viperdoc-u61391.html
Tue Jun 09, 2009 6:01 am
Kind of and intersting tidbit....I actually try to fill up when my car hits halfway empty (or halfway full depending on your disposition). I read a review about gas mileage and it said that the lower your tank gets, the more gasoline you lose to evaporation in the tank itself. Apparently, as the gas level goes down in the tank, the vapor pressure above the gas level lowers, which prompts more gas to evaporate, raising the vapor pressure back toward equilibrium. Kind of a nerdy answer, but I have tried filling up at halfway vs waiting until almost empty, and my gas mileage gets MUCH worse if I wait, even given the same driving habits. Plus is makes sense from a physics point of view. This principle is apparently why the gas tanks at gas stations (the big ones underground) have "movable ceilings" so that as the level of gas goes down, so does the ceiling of the tank, so the vapor pressure stays constant and you don't lose much to evaporation.
