Accouple quick questions
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
Allright, my car is SO close to running its not even funny. Just a few things left and I hope it will fire.
I got accouple quick questions though.
1. Do i really need that retarded Charcoal canister and if not what do i do with the vacuum lines coming off the throttle body and the other line that looks like a fuel? line coming off the bottom?
2. What do i have to do with the lower transmission harness to make it work? I went from an Auto Single Cam KA to a 5 speed SR?
3. I had something but forgot it, ill ask it later i sapose.
Thanks
Gramentz
Car: s14
1. I did not use that charcoal canister either. I believe it is only used for emission purposes.
1-a. Vacuum lines- bottom outlet nipple on throttle body would go to that canister, but you can just get a vacuum cap and block that off. Larger one on top goes to blow off valve. The other one on top goes to FPR, throw a T in there and run a line to your boost gauge.
2. Definitely make sure your speed sensor is plugged in and the correct speed sensor is in there. The reverse position swith is worth hooking up because it makes your reverse lights come on. (Don't have mine, and it sucks backing up at night). You should try and hook up all of them if you can, some of the plugs may not directly plug in to one another, so you can cut and solder or make your own plugs.
3. Ok.
4. Heavy throttle has a great sr install FAQ. Check it out!
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
Allright, so im gonna chuck the charcoal canister cause its in the way.
Question though, I have a turbonetics wastegate, Its got two outlets for vacuum lines.
1's on top, 1's on the side. I know that one of them has to go the intercooler piping like directly after the turbo. Witch one is it? and whats the other one do?
Hum, i KNOW theres something else.... hum..........
Oh, and DO I have to extend the Power steering sensor wire? What is its Exact purpose in life?
