Accident, I need your opinion *PHOTOS* ...
MCNPathfinder
Car: 2001 Nissan Pathfinder 3.5 LE!
Hey guys. So I got into a little trouble with my Pathfinder. I'm pretty disappointed. I was coming home and it was like 2:30a. All the roads were super icy. I stopped at a stop sign on the exit of the freeway. I had the car in "Auto" and let my foot off the brake, without any real throttle or use of the gas pedal, and made a left turn. The speedometer wasn't even really reading any thing, that's literally how slow I was going. So I gradually make the turn, and I realize that I'm starting to slide and heading straight for this guard rail. At that point I pretty much knew I was going to hit it, luckily I was able to get most of the car away from it, but it still nicked it on the back end on the passenger quarter panel. I guess it could have been worse, but I'm still pretty pissed. What do you guys think? Anyone else have this same situation? How much to get it fixed do you suppose? I've been looking at other threads about accidents and am a little bit concerned with the term uni-body. Not like the rear quarter panels are something you can take off and replace on most cars anyway. Just mainly looking for an idea of what kind of work is going to be involved and whether or not you think it's going to be expensive to repair. I'm already pretty much counting on it costing at least $1000. I'll go try and get some estimates tomorrow. Here are some pictures.
DSC03231 by magi628, on Flickr
DSC03230 by magi628, on Flickr
DSC03232 by magi628, on Flickr
DSC03233 by magi628, on Flickr
DSC03234 by magi628, on Flickr
DSC03235 by magi628, on Flickr
DSC03236 by magi628, on Flickr
DSC03237 by magi628, on Flickr
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
To do that job right with a new quarter panel, 2500-3500...
Or just get it pulled, lotsa duraglass... bada bing bada boom rear quarter respray from guy off craiglist $900
Atleast your taillight didnt brake
EDIT: rear bumper plastic looks like it was torn by wolverine in the second pic
MCNPathfinder
How do they replace the rear quarter panel, I was under the impression that really isn't possible. Do they cut it out or something? Which do you think the body shop is going to want to do? I guess we won't really know until I get the estimate. Does it look like it might rust if not taken care of right away? I'm contemplating just getting it fixed in the spring, just in case something else happens during the slippery winter months, you know?
IBCoupe
Car: '08 Nissan Altima Coupe 3.5SE
'19 Infiniti QX50 FWD
'17 BMW 330e iPerformance
They'll find a chunk from a junkyard, they'll cut yours off somewhere (I've seen it usually along the rear door frame) and they'll weld in the new one to replace it.
MCNPathfinder
I took it to Abra, they guy walked out with me and took a peek at it. Told me ballpark about $2200. He said the same thing you guys said, it's possible to cut a chunk out and redo-it, but it might be faster and cheaper to fix this thing. I'm contemplating trying to bump it out myself, putting some primer on there to hold it off until winter is over. I just don't want to get it fixed and then hit something else you know?
IBCoupe
Now that I'm not at a workplace connection, I can see the photos. It definitely doesn't look bad enough to take and get done professionally - at least not cut out. I'd say bump it out, or have a shop bump it out. They should be willing to do it, and probably for less than your insurance deductible.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
QP doesn't look like it will need to be replaced, thats fixable. I would say if you want it done right take it to a shop that will do it right, minimal bondo should be necessary, and maybe a frame jig to make sure the taillight and everything lines up like it should.
and for paint it probably would have to include, bumper, QP and rear door blend- $2200 sounds a bit expensive but I wouldnt expect $1000 thats for sure.
