ACK »
https://forums.nicoclub.com/ack-u211779.html
Tue Jan 01, 2013 7:39 pm
i just had the same fan issue, here is what i did and it got fixed.
removed the harness,
removed the little 2 pins from the harness itself
sanded them , cleaned them and pushed them back into the harness and made sure they wont move, as i applied a drop of silicone at the ends.
rubbed some contact grease
and plugged it back in, and there it was .
if this doesn't work, it might be the sensor itself, they have built in ceramic heat sensors which go bad over the years and looses its connection ability.
good luck
ps if all else fails, check the big blue fan relay under the hood.
