wigenite »
https://forums.nicoclub.com/wigenite-u159041.html
Tue Apr 20, 2010 10:21 pm
Whats the easiest/proper way to replace the accessory belts on an rb20?
When my power steering belt broke, i took it to a autoparts store and had them match one.
I got it on by disconnecting the fuel pump, putting the belt on half way and using the starter motor to pull the belt on the rest of the way.
But now i want to replace the other belt, which is behind the power steering belt. So, will i need to cut the power steering belt off and replace both at the same time? or is there a better way of removing a good belt thats only a couple months old?
Is there a better way of getting the belts back on other than using the starter motor with the fuel pump unplugged?
Also, should i be using those special stretch -self tensioning belts?
