Darius »
https://forums.nicoclub.com/darius-u5470.html
Tue Mar 07, 2006 4:24 am
Do you mean to say that your alternator belt is coming off? If so, it obviously needs to be replaced and/or retightened. There are two bolts to adjust the tension, one loosens to allow the adjustment bolt to move, then tighten it down once the belt is to the desired tension. One bolt is on the top of the alternator, but faces towards you so all you see is the little threaded end poking out at you. You need to stick a wrench in behind that to loosen it.
It's hard to describe, but get in there and look at it because it should be blindingly obvious how it adjusts. If not, there are FSM's around that can guide you through it better.
