Accessing A/C recirculator
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
smj97t
Car: 2007 Versa 1.8 SL Sedan
Newbie.
The arm which controls the lever that opens and closes the recirculator on my '07 has popped off. I can see it and manually adjust it from below, but cannot reattach the pieces. It appears that I could access the rig by removing the cover piece below the steering column. Removing the three visible screws wasn't enough to give me any confidence as to the next step.
How do I remove this section of the "dash"? Is this a move in the right direction? Any help is appreciated.
MJ
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Take a gander at the service manual: http://www.nicoclub.com/FSM/versa/2008_Versa/
Return to “Versa Technical Discussions”
