access to torque convertor bolts
prolandco
Car: 01 nissan frontier 4x4 crewcab, 08 G37, 07 G35X
I'm installing a new 3.3l engine in my 2001 crewcab 4x4 frontier after 228000 miles, and every thing is unhooked except the trans and i can't find access to the torque convertor bolts to take them out. Haynes manuel doesn't say but looks like you have to remove the oil pan from the engine.this can't be true? no access plate on the bellhousing?HELP PLEASE!!!!!
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
As stated in the Nissan Manual:
10: Remove starter motor. Tightening torque: 41 - 52 N·m (4.2 - 5.3 kg-m, 30 - 38 ft-lb)11: Remove gusset and rear plate cover securing engine to A/Tassembly.12. Remove bolts securing torque converter to drive plate.I Turn the crankshaft to expose the next TC bolt and remove it.
I am having some trouble getting the image posted here so check your email for the image instead.
prolandco
Thanks a million should be fine now, if i run into any trouble, i'll check backGreat site love it just got into nissans a few of years ago after being a big ford guy,still like ford but nissan is special just harder to work on, maybe because i have never worked on them ha ha ha they last to long
