nismo1219 »
https://forums.nicoclub.com/nismo1219-u41473.html
Sat Mar 10, 2007 4:03 am
yeah, i learned this the hard way. i used to have to remove the underside splash guards and peel away the fender well just to get access, but thank JLTIBBS ( ) for the info. there is a plastic pop-in screw on the inside of each light, remove said screw, then there are two bolts (i think 10mm but i just used a phillips head) to be removed, after removing all three screws/bolts...the housing should slide out and you'll have complete access to the rear of the light where the bulb is locked in place. hope this helps!!
