Access To 15 Versa Note SV Bluetooth Module
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
15versasv
Car: 2015 Nissan Versa Note SV
How do you access the Bluetooth Module in a 15 Versa Note SV.
It's in the rear passenger wheel well cover.
Looking at the FSM for the 2014 and 2016, (there isn't one for the 2015) it appears to involve a lot of trim removal.
Has anyone ever done this?
Thank you.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It isn't as bad as it looks, you don't need to completely remove the lower trim. If you get the stuff cleared out of the well and remove the bottom pawl-clips on the trim panel, you can detach the righthand side of the welt and pull/bend the rear portion of the panel back and aside without removing it. Hold it back with a bungee while you access the stuff underneath.
15versasv
Thank you!
VStar650CL
Technical Expert
:dblthumb:
Return to “Versa Technical Discussions”
