Postby
WPGQX4 »
https://forums.nicoclub.com/wpgqx4-u136890.htmlSat May 29, 2010 11:34 am
I have a 98 QX4. Sometimes the accelerator feels like it's catching on something. It's only when you start to accelerate. Is there anything that needs to be lubricated or adjusted to get this to stop. It is not catching on the floor mat. Stumped.
Postby
GRNMACHINE »
https://forums.nicoclub.com/grnmachine-u133452.htmlWed Jun 02, 2010 10:34 pm
Had the same problem, possibly the reason I found this forum. Drove me crazy for over a year as it was quite intermittent as well. Exactly what alex said. Unbelievable easy fix. I really thought it was a mechanical problem with accelerator pedal. Clean throttle body and you will be good to go.
Postby
infiniti97qx4 »
https://forums.nicoclub.com/infiniti97qx4-u162215.htmlSat Jun 05, 2010 11:18 pm
same problem here,usually over hot days,
now i have to be silly and ask how exsactly you are cleaning trotle body ?What solution you are using to get rid of carbon ?do you have to remove air intake to get access?
Postby
alexf20c »
https://forums.nicoclub.com/alexf20c-u34818.htmlSun Jun 06, 2010 12:17 am
like i said, use carb cleaner and a rag or shop towel. an old tooth brush will work well also. it's not that hard.
what do you need pictures of? all you do is remove the intake hose and clean the throttle body. ever brush your teeth before? it's like that except the throttle body is your mouth and you're using carb cleaner instead of toothpaste.
Postby
Pathfound49 »
https://forums.nicoclub.com/pathfound49-u150400.htmlSun Jun 06, 2010 10:19 am
alexf20c wrote:lever brush your teeth before? it's like that except the throttle body is your mouth and you're using carb cleaner instead of toothpaste.
Postby
qx41997 »
https://forums.nicoclub.com/qx41997-u162214.htmlWed Jun 09, 2010 2:33 pm
I think that alex desere to be baned from this forum .
I have read more about your behav. and disrespecting attitude in other treads ,what is your issue anyway?
loks like we have great moderators and i am glad they ban you from here .
good luck alex ttying to log in as diferent user.
but you will need new ip address to and change internet service provider
Postby
Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.htmlSat Jun 12, 2010 6:16 am
Carb cleaner is relatively nasty stuff. Wear good rubber gloves. Wash the gloves with soap and water when you are done and they will live to server another day.
