acceleration problems Need HELP ASAP
smitty5806
Car: 93 240sx
tonite when I was leaving out my driveway I hit a huge hump at about 5-10 I think. Well I backed, back and went around it becuase there was huge hump everywhere. So I pulled out and went down the road and stop at a red light. I put the car in first and it to off slow and bog down along with my rpm gauge. So I decided to gun it and the rpms shot up and it took off. Well I continue down the road and pulled over and listen to the motor. Well went I went to take off again it bogged down again as I moderately pushed the gas, then it speed up. This is the first time it did this and I really need a oil change could this be the problem. Or is the clutch ****ed or even worse the transmission.
Vernal
Car: (RIP) 1990 Hatchback 1989 Hatchback
REWORD YOUR PARAGRAPH!!! Really hard to understand.
otterman
I had the same problem when my TPS got all fugged up. I don't know if hitting a bump could knock it outta whack or not though... and I'm not sure how mine got messed up in the first place.
smitty5806
Car: 93 240sx
Think's I really don't think it's a bog issue becuase this morning when I was driving the car shift perfect and it didn't bog down at all.
otterman
Mine was pretty random actually. Sometimes it would drive fine then suddenly it'll act like a ton of bricks was thrown in the back.
smitty5806
Car: 93 240sx
Any Idea what I should do for the problem?
