acceleration problem
dj_lennon_franz
Car: 1992 240sx
got an issue here...i have a redtop just so yah know...ive got this issue at the moment where when i accel at mid to full throttle around 5k rpms (its almost on the dot) the car will start to bog like its lacking fuel...weve checked the timing its fine...weve check the TPS its fine...the MAFS was a concern though the little air sensor thing in it looks fine...i was thinking the problem might be from the fuel pump (im running stock boost right now with a FMIC and air filter) last time something like this happened my fuel pump was going out...took about 3 months for my walboro 255 high flow to take a ****...replaced it with a low flow...its been running fine up until the last few days...anyone got ne suggestions here??? im planning on putting my stock pump back in tomm morning well see if that cures it...if not opinions are more than welcome =)
dj_lennon_franz
Car: 1992 240sx
well i replaced the fuel pump...still pullin the same sh1t...im out of ideas...might try and replace the MAFS...gotta go get my hands on one...anything else i should take a look at???
NY S13 SR
When it happens, what does the boost gauge do? Steady, dropping, up and down? Coulud it be a leak? Intercooler coupling, vacuum line - check them all, it is very common to have a leak cause bogging problems. MAF is a good idea, could be that.
__________________Jeff HHeavy Throttle
dj_lennon_franz
Car: 1992 240sx
my motor usually boosts 10psi from the straight piped exhaust and FMIC...it shoots to 10 psi momnetarily then drops to a flat 7 real quick and doesnt go up at all...usually it holds right at 10psi...im gonna check out the FMIC piping to see if theres a leak ne where...if there isnt gotta start looking for another MAFS
nvsn8
i had the same problem it turned out it was my coils.
dj_lennon_franz
Car: 1992 240sx
fixed it...i had a leak in one of my intercooler pipes (i looked right at it like 8 times lol life is ironic like that isnt it???) now shes boostin like a mustang eatin champ =D
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
wow...when i got trouble w/ my intercooler pipes, they fly off at high speed and my car goes kaput
