Acceleration problem Nissan versa 2008
cnarr
Car: Nissan VErsa 2008
I am having Nissan versa 2008 with 146,000/- miles on it. it suddenly stopped in front of my home . Car is starting normally and when I try to place gear in Drive mode and accelerate it was not moving with even I accelerate at max level it was slowing down.. And when I switch it off and started it back and placed in Parking mode the car is acceleration is good some times.. I did it couple of times but car is not accelerating . can some one help me on this problem.
Will this be an Fuel injection problem? or the spark plugs ? or the transmission
Francesco
Make sure the switch on the brake pedal is not malfunctioning and giving a false signal that the brake is on
Frank 2009 Versa S sedan MT-6 with 71K miles
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
Is it a CVT transmission? If so, you might search "limp mode" for another suggestion. But if so, it would move, just not much. If it's not moving at all, then it sounds like something else...
Siki13
Car: Nissan Versa SL 2008
I have the same problem with my Versa 2008. Than I gone to some service and they clear faults on computer and than its working normally. But I had same problem yesterday
Please help
tikus
Car: Rogue SL AWD Carbon Silver
Check the engine code and see the problems. All sensors are control by computer no more saturday mechanic.
