jerryd1987 »
https://forums.nicoclub.com/jerryd1987-u188669.html
Tue Dec 03, 2013 11:13 pm
sure you got everything bled well? the slave is very difficult to bleed personally i use a pressure bleeder for everything before the slave then pump it up and have someone hold the clutch, loosen the bleeder but then use something to push the piston back in to help bleed the front of the slave. still dosnt work its a clutch, master, slave, or just needs the clutch pedal adjustment rod adjusted. how many miles and has the clutch ever been replaced?
