I have a Nissan Primera (also known as Infiniti G20). Originally it had a standard SR20DE but I've done couple of mods to it, Neo VVL head swap, high performance 4-2-1 extractor (speed daddy), Fujitsubo High flow exhaust and a JWT Pop charger.
Bellow are some pictures of the head swap process, which my mechanic did.
My issue is that acceleration acts weird, specially when cold. Just pushing gently on the gas pedal it starts accelerating and then it decelerates (no matter if I push it further down).
The problem is reduced when the engine gains temperature (harder to notice), and it only seems to disappears when going WOT.
I've looked for vacuum issues but found nothing. I'm thinking it may be a problem with my injectors being dirty or not mounted correctly, but that's just guessing on my part (I'm a car newbie).
Any ideas on what else I should check for? O2 sensor maybe? maybe I'm running lean?
Thanks in advance!
