loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Apr 28, 2010 1:15 am
The TPS, MAF and even the VSS, etc., may be the problem but start with simple/cheap ones and go from there.
Have an OBD II scan from Autozone and the likes. The CEL may be off but you may have ghost codes stored in the ECU. A faulty KS sensor (P0325) will store a fault code but will NOT turn on the CEL, yet will impact your acceleration (and power due to ignition retard).
Check the entire air intake - check/replace the air filter; clean the MAF sensor and connector (CRC MAF Sensor Cleaner will do. Apply dielectric grease on the MAF sensor connector); clean the Throttle Body (do not spray carb cleaner directly in to the TB...use a rug); check for any air intake or vacuum leaks. Also clean/replace the PCV valve. Please note a dirty or failing MAF sensor may not necessarily throw a fault code
You may have a slack on the throttle cable. Make sure the throttle valve is fully responsive to accelerator pedal operation (2nd person needed to do this).
You may have a stuck e/parking brake. Ensure the parking brake is released, jack up the rear wheels and see if they spin freely.
If all of the above are Ok, then you need to check the fuel pressure - 34 PSI with engine running (vacuum on) and 43 PSI with Ignition ON but engine OFF, limited to 5 seconds. Also, one of your cylinders may be bad.
