Destructo1 wrote:I have been seeing a lot on doing this task and i think it would help. Is there a tutorial on this? Or do you have anymore information on doing this? I just dont want to mess it up.. I really appreciate the help!
There isn't a tutorial or anything of the sort but it's a fairly simple process. Just remove the plastic engine cover so you have better access to the various vacuum lines. Just remove one vacuum line at a time and blow compressed air through it to ensure it's not blocked. Now put that vacuum line back on the engine in the original orientation and then pull off a second hose and do it all over again. As long as you put the hoses back on the same parts you will be fine. Some of the hoses will be a little stuck, but it's easier to remove them if you try twisting the end of the hose a little until it becomes free and then it should be easy to pull off.
