I dont know if you were refering to me or both, but i recently swap the maf and made it worse. Didnt even want to idle, would just die. I try to get another maf, one off a working car i had this one laying around for sometime. Btw i did clean the maf currently in my car and still acts the same.asher4857 wrote:try cleaning your MAFS. I remember reading a post a few days ago similar to this and the suggestion to clean the MAFS fixed the problem.
I just did recently like a week ago, i reset it just to make sure but still acts up.Ca_Silvia wrote:Check your timing, both of you
Check injector o-rings. I had the same problem. All injectors were firing but one was more pulsing than firing steadily. There was a small crack in the o-ring. Replaced o-ring and it ran great afterward.red7 wrote: I thought they were the injectores, but there all in working order.
