Acceleration hesitation
SRJesse
Car: Cars, hockey (roller and ice)
Hey guys,
I have a new problem with my 1993 SR20DET engine. It seems like when I drive around town going slowly shifting below 4,000rpms the car is hesitating, almost like buckin back and forth a bit. It only happens when I accelerate slow. I thought maybe it was a spark plug problem, but they are all brand new plugs.
Heavy throttle told me it could be a 02 sensor that went bad.
Could the timing have anything to do with this as well?
I have an exhaust leak and a bad CAT, could that cause this at all too?
Any suggestions are highly appreciated. Thanks in advanced guys...
chrispy
Car: 1990 Nissan 240SX HB
do you have a BOV?
SRJesse
Just the stock one, no after market...
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
Do you have a front mount?
If you've got a lot of intake pipe hangin out under your hood it's going to kill the response time from the MAF to the throttle body. I used to have that problem, and I cheated it a bit by leaning the piss out of my motor at low RPM's, which worked (excpet cold starts sucked). After switching to a blow through MAF the problems went away (now my MAF is 5 inches from my TB and not 5 feet).
Also check your timing, if you give it a bit more advance it might get better (also delt with that issue).
hope some of that might help,
later,
PaulOrlando, FL
ITR_KILLR
if you have a clogged cat, that could be responsible
mattback
Car: being a big f'ng ricer
what is your base timing set to?Also, vacuum leaks will cause heisstations and what not.. those ****ers ruin mafs equipped cars.i agree with paul that could also be aproblem.
