Acceleration explained...
This is a pretty cool little blurb - My Mom actually sent it to me. :)
Ever wonder why a Top Fuel dragster gets a rebuilt engine after each run?
Stay with this- even if you aren't a 'car nut', this is stunning.
* One Top Fuel dragster outfitted with a 500 cubic-inch replica Dodge (actually Keith Black, etc) Hemi engine makes more horsepower (8,000 HP) than the first 4 rows of cars at NASCAR's Daytona 500.
* Under full throttle, a dragster engine will consume 11.2 gallons of nitro methane per second; a fully loaded Boeing 747 consumes jet fuel at the same rate but with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lockup at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug... which is typically the output of an electric arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way thru the run, the engine is 'dieseling' from compression and the glow of the exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow the cylinder heads off the block in pieces or split the block in half.
* Dragsters reach over 300 MPH +... before you have completed reading this sentence.
* In order to exceed 300 MPH in 4.5 seconds, a dragster must accelerate an average of over 4 G's. In order to reach 200 MPH well before reaching half-track, at launch the acceleration approaches 8 G's.
* Top Fuel engines turn approximately 540 revolutions from light to light!
* Including the burnout, the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500 RPM.
* THE BOTTOM LINE: Assuming all the equipment is paid for, the pit crew is working for free, & NOTHING BLOWS UP, each run will cost an estimated $1,000 per second.
0 to 100 MPH in 0.8 seconds (the first 60 feet of the run)
0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
6 g-forces at the starting line (nothing accelerates faster on land)
6 negative g-forces upon deployment of twin 'chutes at 300 MPH
An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle on earth... quicker than a jet fighter plane... quicker than the space shuttle... or snapping your fingers !!
The current Top Fuel dragster elapsed time record is 4.420 seconds for the quarter-mile (2004, Doug Kalitta).
The top speed record is 337.58 MPH as measured over the last 66' of the run (2005, Tony Schumacher).
Let's now put this all into perspective:
Imagine this...........You are driving a new $140,000 Lingenfelter twin-turbo powered Corvette Z-06. Over a mile up the road, a Top Fuel dragster is staged & ready to 'launch' down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard, on up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH.... The 'tree' goes green for both of you at that exact moment. The dragster departs & starts after you. You keep your foot buried hard to the floor, and suddenly you hear an incredibly brutally screaming whine that sears and pummels your eardrums, and within a mere 3 seconds the dragster effortlessly catches & passes you. He beats you to the finish line, a quarter-mile away from where you just passed him.
Think about it – from a standing start, the dragster had spotted you 200 MPH.....and it not only caught, but nearly blasted you off the planet when he passed you within a mere 1320 foot long race !!!!
That, my friends.....is acceleration. :dblthumb:
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I've never been big on drag racing numbers for other types of cars, but I've still always enjoyed watching (especially in person) top-fuel and funny car racing. Despite seeing turbine-powered dragsters in person, I don't find them anywhere near as neat as the piston-powered ones.
The cars are stunning examples of ultra-purposed engineering.
My favorite thing is the fuel consumption. Nevermind what's being done WITH the fuel. Think of the pump that's moving all that fluid! 11.7 gallons PER SECOND. Put the right nozzle on that and the thrust from the pumping fuel alone would probably move your Camry.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I think what's remarkable is that they're able to make materials that don't weld themselves together and the engine can even be rebuilt! Considering what all is happening, it's amazing they can even take the thing apart! Anyone who's seen an overheated engine knows how much of a boogered up mess they become.
The fact that I can idle my car for 1 minute, and the engine has turned more RPM than a dragster during it's entire run is amazing.
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
Top fuel is both amazing and ludicrous to me. Insane amounts of power/speed generated but I shrug when I think about all that money, power and effort just to do something once (or twice if lucky) that's over in under 5 seconds.
RicerX
Car: '20 Titan Pro4X
This was a SUPER COOL read to start the morning.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
This^^ :werd:
That's great but a Corolla will do 200,000 miles.
/whatatoyotafagwouldsay
yodawill2000
Car: 94 Infiniti J30
I never miss the Fall nationals down here in Texas.
Sitting on the front row about 100 feet from the Start is a sensation like no other.
It shakes every bone in your body.
:dblthumb:
elwesso
2007 BMW M Coupe
Bubba1 wrote:Top fuel is both amazing and ludicrous to me. Insane amounts of power/speed generated but I shrug when I think about all that money, power and effort just to do something once (or twice if lucky) that's over in under 5 seconds.
The same could be said about someone who wants to drive around a racetrack for a certain amount of time, ultimately you're still going in circles regardless if there's left and right turns, or just left turns.
Realistically it all boils down to this...... Doing anything to a vehicle outside of using it for your basic transportation needs is pretty pointless, so now we're arguing about the degree of pointlessness...
Bubba1
2024 Honda HR-V
elwesso wrote: The same could be said about someone who wants to drive around a racetrack for a certain amount of time, ultimately you're still going in circles regardless if there's left and right turns, or just left turns.
True, but you can get a ton more seat time doing the stuff with turns as compared to drag racing given the same investment.
For some, it's quality over quantity.
elwesso
2007 BMW M Coupe
I told one of my coworkers about how those cars have 8G's of acceleration when they launch.... All he said was, I hope that the drivers go to the bathroom before hand, because no one's butthole is strong enough to hold in a burrito at 8g's... :blush:
sx moneypit
1986 Toyota MR2
:rotfl :chuckle:
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
AZhitman wrote:For some, it's quality over quantity.
Right. I'd rather make a 3 second run in a dragster than a 10 minute lap around Road America in an Echo.
Bubba1
2024 Honda HR-V
And I think many guys would prefer a 1:30 lap of VIR in an F1 racecar than a 30 second 1/4 mile run in an Echo. I don't follow you.
FWIW, I totally agree with Greg. For some it is quality of over quantity, and that's fine. But call me crazy and miserly. If that level of cash was coming outta my own pocket, I'd prefer to spend it on hours of fun, not a few fleeting seconds. (That's not to say those few seconds in a top fuelie aren't great).
themadscientist
The amount of adrenaline rush and concentration it takes to snap off a quick blast in a fast street car is intoxicating. I can't imagine what the near death experience trying to direct a land-hugging missile from zero to crushed eyeballs must be like.
It must be easy and boring. Some pizza-faced drifter kid explained it to me. :rolleyes:
I love any car driving. Drag appeals to me most, but highway running is exhilarating. Drifting is fun, but it's not that exciting to me. The idea of doing a road course where my performance is not subjective and can easily be measured by where I finish appeals to me far more than sliding around.
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
Just one thing I would add to this, one of my desktop background pictures at the office:
audtatious
When they can turn left or right without wrecking I'll be impressed
flohtingPoint
Car: 2004 Z16 Corvette Z06
audtatious wrote:When they can turn left or right without wrecking I'll be impressed
You know you wish you could sit in the seat for one run... =P I turn left and right constantly, but never get put in my seat like this. This type of force is something only them and astronauts get to experience.
It's got to be a near-death experience.
The other thing I think is amazing is this: Look at the age of most Top Fuel and Funny Car drivers. Amazing.
Bubba1
2024 Honda HR-V
AZhitman wrote:It's got to be a near-death experience.
And how some of them look. John Force's daughter is cute. :naughty:
As I recall, three are two of 'em. Saw one of them at SEMA.
themadscientist
8000hp doesn't corner. That's like trying to execute a turn in a Saturn 5 rocket.
Ride along.
http://www.youtube.com/watch?v=HE9ECG6ifOE
