accelerating and shaking
fsjlk1
Car: g35
okay im new got a 04 sedan 6mt and when under high accelearation vibration occurs and i am thinking its the axles but im a newb
zozoka1212
Car: 08 Infiniti G35x
Ballancing wheels, suspension,wheel bearing , uneven tire wear or even motor /transmission mounth can do it just to name a few. Is it feels like at the wheel? Try to lift it up and spin the tire move the wheel side to side to see if it got any play. Inspect the tires check if you have lost a ballancing weight maybe.
If it did not do it before my money is on the ballancing of the tires so I would check that first to see if the ballancing weight are on. If you have not ballanced the tires you should take it in and get it done.
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
high acceleration as in full throttle acceleration?
Nazc0
Car: 2004 G35 Sedan Gray
if its just when you stomp on the gas even with the vdc on it might be the tire breaking loose depending on the road surface and while really going for it any pothole or bumps can cause the wheels to break traction but if its just a constant vibration i put my money on the wheel weights
fsjlk1
Car: g35
vdc off ill check balancing thx for the help guys
Nazc0
wait you complaining that the car shakes when you go off with the vdc off at full throttle?like i said depending on the road surface it might break traction
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I've had the traction issue before. Almost feels like what I'd think tire wrinkling would feel like. Slip, grip, slip, grip. Not really a great feeling. I like full traction loss
telcoman
fsjlk1 wrote:okay im new got a 04 sedan 6mt and when under high accelearation vibration occurs and i am thinking its the axles but im a newb
Are you driving on paved roads or over a glacier?
Telcoman
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
I couldn't help but smile when I read this... wouldn't you expect that under hard acceleration?
But just like I was just telling my little sister, don't drive your car hard if you not in tune with what is "normal" for your car.
please drive your new car and get used to it before you drive it hard.
+1 get your wheels and motor mounts checked.
