VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Oct 13, 2022 4:25 pm
You need to see if the dealership uploaded the CVT-A/CVT-B values from the TCM. Those are an "overheat record" as opposed to codes, but they'll be the only evidence if your transmission is running hot. You need to do an extra operation to read them with the dealership Consult scanner, and if there aren't any codes, guys often forget to look. The problem is that the TCM doesn't throw codes or turn on the MIL for overheating, it simply goes into limp mode until it cools off. But it does record each episode in CVT-A/CVT-B, so the evidence will be there if you look. Both parameters should be zero. If they aren't, then your transmission has a metaphoric hot-foot.
You can read the values yourself for under $20 if you have a Droid phone. Get an ELM327 adaptor for your OBD port and download the CVTz50 app. For the adaptor I recommend a VeePeak VP11, it's the cheapest ELM327 that works right with CVTz50 (not all do). Once you get hooked up, hit the "CVT INFORMATION" button and your CVT-A/CVT-B record will be right there.
Vis a flush, any sort of back-flushing is a no-no. You're much better off doing a couple of quick spill-and-fills (say, 1K apart) and drop the pan for one of them to clean out any gunk (there will definitely be some black residue and metal on the magnets, how much you see of each will tell you a lot). There's nothing wrong with taking the radiator heat exchanger loose and back-flushing that if you want to, but make sure you use a CVT-compatible solvent. If in doubt, Nissan sells a canned one. To keep the cost down, go with a good aftermarket fluid like Eneos, Indemitsu, or AMSoil in lieu of NS3. I personally like Eneos Eco, it's almost the same color as NS3 and actually outperforms it. None of the three I mentioned have miscibility issues, they'll all mix freely with the existing NS3.
