acc relay click after swap?
2ueceka24de
Car: 89 240sx 93 ka24de
so i just did a 96 swap into my 91 and now my acc relay clicks(once), nd under the sterring colum too i know there is anotha acc relay there. this never happened bofore the swap so i wanted to get pointed in the right direction because i doubt the ralay gave up during the swap. and searching is comming up with all sorts of different problems. i do have three plugs that are not plugged in... would this b a reason.
will try seeing if the relay is bad today and will update also i do not have an volt meter...........but will have one soon i hope :bs: .. is it suppose to be .05 ohms? also b4 the swap as soon as b+ is connected my accesory lights stay on with key out of ignition, heard this is a common problem where is the ignition switch located?? nd how do i test
Thanks u for the input nico :chuckle: :werd:
2ueceka24de
4got to state car does not turn on jus the relay click
Hijacker
Car: '92 240sx Convertible
'94 F-150
For such a specific issue you're having, you have given very little information. What did you do for the efi harness? Are you getting power to the accessories? Do you have any blown fuses? I'm talking about the big fuses in the engine bay relay box. And what plugs did you leave unplugged?
2ueceka24de
sorry got the car to crank but wont start did compression test 90 110 110 90 but the motor should still start i am running a emanged tuned ecu and im thinking thats the prob will post if i get it up and running
