Recently my accessory power (dash lights, stereo, cig lighter, auto seatbelts) would remain on after removing the key. At times if I would depress the brake pedal (and the current draw from the lamps would trip the relay?) it would shut off but now I have to disconnect my negative battery cable to shut it off. I have replaced both the ECC and Acc relays under the hood and still remaining on. Could it be the ignition switch, everything shuts off after I disconnect the neg cable and stays off when I re-attact it. I have disconnected my Mobile ES headunit, the Mobile ES dsp/eq unit, and all the amps, completely.
The engine is out of the car now (waiting for the KADE oil pump cover to cone off backorder before I can stuff it back in) and I connected a new Optima redtop (that I stuck on my bikes Battery Tender for a week) that was fully charged so I know its not lack of voltage.
Any ideas? Thanks way in advance! Marc1991 S13 w/KA24DE(T)
Modified by NJMarc at 11:00 PM 7/11/2006
