evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Oct 20, 2014 6:53 am
Digital or analog climate control? This whole adding a vac pump is bugging me. The heat and air require only 2 vac sources, the first activates the heater valve in the heater lines on the firewall, the other goes through the firewall is serves to "power" the dashpots that move the selector doors and blend door. There is no vac line dedicated to the a/c. Many people have the hot air problem which is a stuck or cracked bellow on a dashpot adding a pump would not fix the problem. On miata the blend door gaskets deteriorate and allow for hot air to leak through, you can reset the cable in the stay to add some tension to close tighter.
