vonscorpio wrote:I thought the AC compressor oil usually has a brightly colored dye mixed in. It wouldn't look like water/condensation
I've had this scenario play out a few times, including on the QX4. When the A/C starts getting noticeably weak, usually after a number of years, I immediately take it into a A/C repairer (it's hard on the compressor to run with low refrigerant, and the last thing I want to do is lunch the compressor, $1000+ to repair.)
Each time it's been about 8 oz low, out of 32-36 oz, and about $80 to top up. A UV dye will be added at the same time. They will check around hose connections with a UV light for any leakage, if not, it's normal loss and you're good to go.
Normal condensation will be just water, no oil feel to it.
