Madnance »
https://forums.nicoclub.com/madnance-u9841.html
Sun Sep 21, 2003 5:02 pm
I have a 1993 J30T. I took it on some long drives in sunny calif the past couple of months and the AC always starts out strong, blowing good and nice and cold. But afer maybe 20-30 minutes, the volume of airflow drops and eventually gets to a very low level, like when the fan is set to minimum, though it is set to max. My brother said the condenser may be freezing, restricting air flow. So I tried setting it to "economy" when the problem re-ocurred thinking that this would turn off the AC and blow hot air across the condenser to melt any ice. Sure enough, this quickly brought the airflow back to a high volume, and the AC worked great when turned on again. But 20 minutes later I was back to the same problem.
Sure I can cycle it on and off myself but I thought I'd check and see if any experts know whats happening here and how I can fix it.
Thanks
