You probably just need to let out the excess you put in. The ECM shuts down the compressor when the refrigerant pressure is too low
or too high, so overcharging will shut it down just as reliably as emptying it.
For reference, at room temperature your low side should run 35-ish and your high side 120-ish. That also depends on humidity, so there's a range. See ATC-104 here:
https://www.nicoclub.com/service-manual ... %2Fatc.pdf
Your compressor is a swash plate type that will run whenever the A/C is on, so you should see little or no variation in pressure at idle. It won't cycle, the IPDM just orders more or less swash according to the demand.
