datechboss101 »
https://forums.nicoclub.com/datechboss101-u271130.html
Tue Jul 23, 2019 9:17 am
1) I commute between Miami and Orlando weekly and its the temperature inside when its cold enough, that it starts to bring in outside air on its own. Mine does this frequently, so I lower the fan speed to make sure it stays in Recirculation mode.
2) Was someone shorter than you using the vehicle that set the lower height? And to raise the tailgate, higher, you have to replace the hatch struts to ones that allow you to lift the hatch higher. But then you have to deal with the hinges at the top of the hatch, which goes all the way back to its limit.
