AC stumble problem?
T.X.240guy
Car: 1995 240SX
I just got a 95 240Sx and when I turn the AC off it idles around 600 and 100 rpm. I replaced the battery terminals, distributor cap and rotor, plugged some fuel injector cleaner right into the fuel rail, cleaned the throttle body, and nothing helps. the car runs fine until i turn the AC off, until tonight! i put a full tank of gas in it and it's starting to stumble with the AC on too. theres about 139,000 miles on the engine any inputs?
navysnail
sounds like you may have a problem with your IACV or your accessory air control valve
zerothread/26039
T.X.240guy
Car: 1995 240SX
Whats a IACV and where can i buy one, and the air valve thing??
180fan
Car: 89 fastback
they're usually on the same assembly. you need to contact a dealer for that part. good luck they're expensive.
